bdmcgal
#1 Posted : 16 years ago
bdmcgal
My dryer makes a loud squeaking noise during part of drying cycle, it stops for a while, then repeats. Any ideas on what may be causing this problem.
BM
#2 Posted : 16 years ago
Here is the parts breakdown
Model MDE5000AYW
And here is a service manual
http://www.servicematters.com/m...ibrary/docs/16023110.pdf
Could be a number of things. Check the front glides, rear suspension rollers, idler wheel, motor, blower wheel.
Also check for anything stuck between the drum seals and the case.
Check for slop in the bearings and wear on the shafts, the most likely culprit is the idler wheel. Also check the belt.
Give the interior a good cleaning.
Might as well clean and check your vent system while you are at it
Maytag Atlantis dryer....LOUD squeaking noise (Dryer Repair)
by kimber23ks 14 years ago
Loud squeaking Noise (Dryer Repair)
by Peter687 15 years ago
ge dryer is making loud squeaking noise (Dryer Repair)
by georgepannier@sbcglobal.n 17 years ago
Loud squeaking noise during spin cycle (Washer Repair)
by thwillis99 17 years ago
