jmwr
#1 Posted : Tuesday, July 26, 2011 5:31:55 PM(UTC)
jmwr
My Maytag, propane gas oven will not light. The lower burner has been slow in lighting recently, but would eventually light. Today, the pilot light would come on and stay on, but the burner would not light even after waiting about 15 to 20 mins. If I set the oven to broil, with the upper burner only, that would light. But if I set the broiler to come on for both the upper and lower burners, the oven would shut off. Any suggestions as to what may be wrong???
Thanks so much for any and all help!
Jeff / APP Team
#2 Posted : Wednesday, July 27, 2011 10:32:00 AM(UTC)
Jeff / APP Team
Hello jmwr. It sounds like you have a weak igniter. You will need to test and see if there is 3.2-3.6 volts AC at the gas valve with the igniter turned on. If not, you will need to replace the igniter. If the proper voltage is there, you will need to replace the gas valve. You can test this with a multi-meter [AP3873826]. Here is a link on how to use a multi-meter. Hope this helps.http://forum.appliancepartspros...continuity-ohmmeter.html
Part number: AP4096256
