guingueomo@hotmail.com
#1 Posted : Wednesday, July 27, 2011 6:49:18 AM(UTC)
how could take out the old upper dishrack assembly AP2040321(WD28X10049), to install the new one.
there are plastic stops at the end of the rail & they will not come off so i can not slide out the rack to be replaced
i will appreciate your help
thanks
guingueomo
Jeff / APP Team
#2 Posted : Wednesday, July 27, 2011 11:26:19 AM(UTC)
Jeff / APP Team
Hello guingueomo. The end caps have tabs on them that needs to be pressed in to release the end caps from the rails. Once you press the tabs, you will pull the end caps out of the rails. Hope this helps.
Part number: AP4484666
