Ken Martin
#1 Posted : Friday, July 22, 2011 7:39:35 AM(UTC)
Ken Martin
The dryer starts and runs as normal. The heating element is operating,after about 45 seconds one of the breakers trips,the element goes off. The rest of the dryer stays running. I have done this many times with same result. HELP Thanks
#2 Posted : Saturday, July 23, 2011 3:45:13 AM(UTC)
You said that only one breaker trips so unplug the unit and switch the Black (L1) and the Red (L2) on the terminal strip in the unit.
Plug it back in and give it a try.
If the same breaker trips then I would say that the breaker needs replacing.
If the other breaker trips unplug the unit and check the heating element.
Unplug both wires to the heating element.
Check it with a meter, should be around 10 to 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to draw too much power.
Be sure to put it back the way it was when you are done.
FYI: You have an electrical code problem, at least the code in my area. The two breakers for the dryer should be ganged (tied together) so that if one trips it also trips the other one. Sometimes this is a small rod that ties the two breaker switches together.
In this case not having them ganged may help you trouble shoot but you may want to gang them after the repair.
Ken Martin
#3 Posted : Tuesday, July 26, 2011 12:21:32 PM(UTC)
Ken Martin
Hi DENMAN, Thanks for the info. I have 10 ohms on the coil and no continuity between the coil and the case. I originally moved the the power from a ganged breaker to 2 breakers to test breakers and what would happen to the dryer. Any thoughts of what I should try next? Thanks for all the help. Ken
#4 Posted : Wednesday, July 27, 2011 3:08:32 AM(UTC)
Replacement parts for WHIRLPOOL GEW9200LW1 Electric Dryer | AppliancePartsPros.com
Here is a manual
http://appliancedigest.c...ic-dryers-service-manual
You have to join the site to download the manual but it is free and this is a very good site for manuals and other info for the appliance repair DIYer.
And finally see the attachment for the tech sheet
Changing the unit to different breakers seems to kill my bad breaker theory.
Looks like the heater side of the line is the culprit.
I would remove the heater and check the inside of the case for any tell tale signs (weld marks etc.) of the coil sagging and touching the case when hot.
This is a bit of a long shot as usually it would weld itself to the case.
Check for any signs in the heater wiring that it is shorting once the unit warms up.
Check the voltages perhaps there is a bad connection in that side of the line which is dropping the voltage and causing a higher current flow.
If all OK I am at a loss as to what is going on. The only thing you could try is getting/borrowing a clamp on ammeter and monitoring the current flow into the unit.
L1 to L2 should be 240 volts
If OK
If OK
File Attachment(s):
GEW9200.pdf (327kb) downloaded 3 time(s).
Breaker trips after 45 (Dryer Repair)
by Ken Martin 7/26/2011 12:56:42 PM(UTC)
