Washer spins but won't spin fast enough or shift gears
Check out the drain hoses and pump, make sure they are not clogged. Then use this guide to see if you are getting an error code. Before doing anything clear out the codes and see if that fixes things. A lot of times it does. HydroWave GE Washer Repair Guide
