j34castro
#1 Posted : Tuesday, July 26, 2011 12:51:39 PM(UTC)
j34castro
Had Ice on coils, tested defrost heater, was okay. Replaced Defrost timer control. Freezer gets cold (-10), refrigerator cools to 40~50 off and on.
Controls for refrigerator, freezer are all set to max (all the way to the right). Evaporator fan seems to be running okay.
Suggestion are welcomed.
Jc
#2 Posted : Tuesday, July 26, 2011 4:00:25 PM(UTC)
JC,
The refrigerator cools down with the cold air coming from the freezer. You have to check the window between thees sections for any obstructions. Make sure the air gate is operated properly.
Here are the breakdown diagrams and Replacement parts for JENN-AIR JCB2388ARW REF - SXS | AppliancePartsPros.com
j34castro
#3 Posted : Wednesday, July 27, 2011 10:05:44 AM(UTC)
j34castro
Where is the air gate on the schematic?
#4 Posted : Wednesday, July 27, 2011 4:43:32 PM(UTC)
It's not illustrated. It it on the top of the wall between the sections, close to the rear panel. From the freezer it's covered with the air inverter (#35 on the diagram).
