My ice maker is overflowing. The ice cubes were getting bigger and bigger. Then I turned off the icemaker on the button on the front control panel and now it has continued to drip and mound up on the ice tray and down into the ice dump bin. What is need to get the water to stop dripping once the ice maker has cycled through and filled the ice tray?
Originally Posted by: jchwrh  My ice maker is overflowing. The ice cubes were getting bigger and bigger. Then I turned off the icemaker on the button on the front control panel and now it has continued to drip and mound up on the ice tray and down into the ice dump bin. What is need to get the water to stop dripping once the ice maker has cycled through and filled the ice tray? did you ever get an answer to this problem? i have same issue thanks
