2 Pages12>
gutter
#1 Posted : Monday, July 25, 2011 5:48:47 PM(UTC)
gutter
My freezer door was left open over the weekend for two days and when I came home there was a puddle of water under the fridge. After removing the bad food from the freezer I noticed that the GFI circuit it was on was tripped.
Trying to reset it I heard the ice maker trying to fill, so I truned the ice maker off and the fridge and freezer work fine again.
I took the ice maker off and apart and it appeared to not have any water or residue from anything melting inside the maker but to you have any ideas of what to look for next? As soon as it calls for ice again it trips the GFI.
Serial #LL216319
On a side note for a while it has also made a whislting sound while running and it sounds like it coming from the evap fan. Any thoughts on that?
Joe / APP Team
#2 Posted : Tuesday, July 26, 2011 8:35:29 AM(UTC)
Joe / APP Team
Serial #LL216319
Gutter,
I can't help but think, you have a problem in the ice maker ontrol module,
Part number: AP4345120
Here's a way to check, Run the service diagnostic test and see if the GFI opens.
If it opens, disconnect the wires from the icemaker solenoid of the water inlet valve on the back of the machine, and re run the test. If the GFI opens, we have a bad control in the module, or a pinched / shorted wire. If the GFI does not open, we have a shorted water inlet solenoid.
Part number: AP3192626
Service Diagnostics
During the first 15 seconds that power
is first applied to the icemaker, the Service
Diagnostic Test mode may be entered. The
service mode is entered by pushing the feeler
arm from the outposition to the inposition
and back again 3 times and only 3 times within
15 seconds.
The service diagnostic mode consists
of a harvest cycle followed by a water fill. The
harvest cycle is entered immediately, regardless
of icemaker temperature or arm position.
Either way, you'll be up and running in no time.
Good Luck,
aggieemt
#3 Posted : Sunday, April 30, 2017 2:15:38 PM(UTC)
aggieemt
I can't seem to enter the Service Diagnostic mode, however, I think I have narrowed it down to the fill valve.
When I turn the icemaker on, the GFI doesn't trip right away; the harvest cycle will complete without a problem, and trips during or after the fill cycle completes (not sure if it completes, but there is at least some water in the ice tray when it trips)
Sounds to me like a bad fill valve, but I want to be sure. Can someone confirm or point me somewhere else?
Whirlpool GD5HAXTL01
Joe / APP Team
#4 Posted : Monday, May 1, 2017 6:23:43 AM(UTC)
Joe / APP Team
aggieemt, Your refrigerator is a different brand, so the posted service information is a bit different. But the procedure is very similar. In your case you will need a piece of 14 gauge wire a couple of inches long, remove about 1/2 to 3/4 inch on both ends of the insulation. Disconnect the tan and white wire from the fill valve. Open the freezer door and tape the door switch down. Access the front of the ice maker and remove the cover. Insert one end of the jumper wire into the opening labeled "T" and the other end of the wire into the opening labeled "H" and hold them there until the arm rotates to the 9 o'clock position. Allow the ice maker to rotate until it reaches the 3 o'clock position. If it rotates through the complete cycle, the fill valve has failed. If the short occurs and trips the GFI, then the problem would be in the control head and or wiring to the fill valve.
aggieemt
#5 Posted : Tuesday, May 2, 2017 8:30:23 AM(UTC)
aggieemt
The arm rotated to about 7:00, and I tipped the unit to help get the partially frozen cubes out, and now it won't continue the rotation, even with it still jumpered.
I might not have been clear in my first post... it trips the GFI immediately after filling the tray (or in less time than it takes to start freezing the new batch of ice after a harvest cycle).
With the unit jumpered and the full valve disconnected, it won't rotate past 7:00 and it doesn't trip the GFI.
When I reassembled everything, the bar continued to rotate, it filled, and is now freezing without tripping the GFI.
Does that give you enough info to point to a problem?
Joe / APP Team
#6 Posted : Tuesday, May 2, 2017 10:40:28 AM(UTC)
Joe / APP Team
Aggieemt, Now it sounds like you have a faulty mold heater or thermostat ?
Let's do it like this. When the rake arm reaches the 1 or 2 o'clock position, the cycle has ended, and the ice maker mold should have filled with water. When you insert the jumper wire, and the arm rotates, when it reaches the 2 o'clock position, the thermostat is closed and the heater is on. At the 4 o'clock position, the rake arm will "stall" on the cubes until the heater "loosens" the cubes from the mold, then will rotate to the 7 o'clock position, the thermostat opens and turns off the heater. The arm will rotate and dislodge the cubes and they should slide down the cover and fall into the ice bin. At the 11 o'clock position, the water valve is energized and fills the ice maker mold, then the arm rotates to the 1 or 2 o/clock position and the cubes start to freeze, when the thermostat in the mold reaches 14 to 15 dgrs. the thermostat closes and the cycle should start all over again.
If you have a multi meter, insert the meter probes into the openings "T" and "H" you should read an open circuit, unless the temperature is less than 10 to 14 dgrs. Then insert the meter probes into the "L" and "H" openings, you should have a resistance reading of 70 to 80 ohms. (Make sure you remove power to the refrigerator first). Let us know what you find.
Joe / APP Team
#7 Posted : Tuesday, May 2, 2017 10:41:21 AM(UTC)
Joe / APP Team
Let's do it like this. When the rake arm reaches the 1 or 2 o'clock position, the cycle has ended, and the ice maker mold should have filled with water. When you insert the jumper wire, and the arm rotates, when it reaches the 2 o'clock position, the thermostat is closed and the heater is on. At the 4 o'clock position, the rake arm will "stall" on the cubes until the heater "loosens" the cubes from the mold, then will rotate to the 7 o'clock position, the thermostat opens and turns off the heater. The arm will rotate and dislodge the cubes and they should slide down the cover and fall into the ice bin. At the 11 o'clock position, the water valve is energized and fills the ice maker mold, then the rotates to the 1 or 2 o/clock position and the cubes start to freezer, when the thermostat in the mold reaches 14 to 15 dgrs. the thermostat closes and the cycle should start all over again.
aggieemt
#8 Posted : Wednesday, May 3, 2017 1:50:47 PM(UTC)
aggieemt
OK, the circuit from T to H is closed, and resistance across L and H is normal. You referenced the temp of 10-14 degrees... I'm not sure what the temp inside the freezer is, as I'm working on it as the freezer is still in service.
Today I happened to catch the ice maker at the end of the cycle: I taped down both door switches and watched as the arm rotated through a complete revolution to the 1:00 position to dump ice, then filled the trays. Knowing this was where it typically trips the GFI, I stood and watched for 2+ minutes waiting for it to trip, but it never would. I closed the door to leave and the GFI immediately tripped. Opened the door, reset the breaker, and the breaker stayed closed until I shut the door, and it immediately opened again. Repeated this 3-4 times to make sure it wasn't random timing.
Turned off the icemaker switch, reset the GFI, and I can open and close the door all day long and it won't trip.
So, it seems that it has something to do with a process at the beginning of a cycle that only occurs when the door is closed....
And tonight it completed 2 full cycles without tripping the GFI. I'm thinking maybe there are gremlins in it....
Joe / APP Team
#9 Posted : Thursday, May 4, 2017 5:20:18 AM(UTC)
Joe / APP Team
Aggieemt , Reviewed the posts and realized we didn't recommend the first and easiest check. Remove the lower kick plate and hinge cover, and check the wiring harness and connector at the door hinge. You may want to remove the door to be extra thorough. The harness in the bottom of the door and hinge can fray and break causing intermittent or erratic operation of the dispenser assembly.
aggieemt
#10 Posted : Thursday, May 4, 2017 6:27:10 AM(UTC)
aggieemt
Ice maker ran all night without tripping the breaker.... I'll check the lower harness, but there has been no problem with the in-door dispenser...
Guest (4)
2 Pages12>
