oldmill
#1 Posted : Monday, July 25, 2011 12:33:12 PM(UTC)
oldmill
I have replaced defrost heater which was visibly burned out, and it is still not functioning in defrost cycle. Defrost timer seems to test OK with 1.5 volt test light, but no power at defrost heater quick connect in freezer compartment when in defrost cycle.
1-Can the timer be faulty and still show continuity?
2-Unable to locate heater fuse as shown in parts diagram. Where is it?
Thank you
#2 Posted : Tuesday, July 26, 2011 4:40:24 AM(UTC)
Here are your parts, includes the wiring diagram.
[COLOR="DarkRed"]2-Unable to locate heater fuse as shown in parts diagram. Where is it?[/COLOR]
The fuse is Item 16 in Section 3. I am not sure where it is but it is probably clipped onto the evaporator coils just follow the defrost heater wiring.
If someone else has worked on this unit they may have removed it as it is no longer available.
[COLOR="DarkRed"]1-Can the timer be faulty and still show continuity?[/COLOR]
I am not sure what a 1.5 volt trouble lite is.
Also not sure how/where you are testing continuity with the trouble light.
Trouble lights are like the idiot lights on a car they really do not tell you much, a meter is a much better tool for trouble shooting.
That way when measuring for resistance you know what it actually is, the same applies with voltage.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
oldmill
#3 Posted : Tuesday, July 26, 2011 5:43:51 AM(UTC)
oldmill
Thanks denman,
The test light is one I use for testing auto circuits etc and it is 3 volt DC battery unit and simply indicates if a circuit is open or has continuity. I do have AC/DC, volt, ohm and amp meters but did not use them in this case. Since my post I have found no power reaching the heater when timer in defrost cycle and ordered a new timer.
I have found a on-line supplier who accepted my order for a heater fuse so will have to wait to see if it gets filled.
It appears originally the manufacturer felt a heater fuse was beneficial as per the parts list. I am not sure my unit ever had a one in it. I will put a fuse in it if I get one. I suppose the wire heater element itself in some form serves as a fuse. (burn out as my old one did). One could question the value of the fuse ahead of the heater element. Thanks again..
Guest (4)
