rhartley247
#1 Posted : Tuesday, December 9, 2008 11:01:08 AM(UTC)
rhartley247
ices upMy GE sXS freezer ices up as soon as the ice maker is full. Heaters Ohm out ok door heater works. Timer seems to run slow. How can the defrost thermostat be checked?
Coils frost up within 30 minutes of manual de iceing.
where from here?? ;)
abadfish66
#2 Posted : Tuesday, December 9, 2008 11:36:53 AM(UTC)
abadfish66
The coils are suppose to have frost on them, a light snow frost pattern is normal, Iced up solid is not good. So for proper diagnosis frost on them after 30 minutes is normal, what is the problem?
rhartley247
#3 Posted : Monday, December 15, 2008 7:28:11 PM(UTC)
rhartley247
Replaced the timer and freezer temp sensor everything working just fine now.
Thanks for your excellent Q&A file, it is a big help
P.S. yo;ur package arrived about 40 hours after my on-line purchase. Great Work!
See Ya...not real soon I hope ;)
