DoSchultz
#1 Posted : Thursday, July 21, 2011 12:31:02 PM(UTC)
DoSchultz
Whirlpool Laundry Center ThinTwin unit - at the spin cycle, the washer motor runs but the drum will not spin with or without clothes in the machine. There is a buzzing sound maybe such as a stripped gear or something not "catching" to make the drum rotate.
The unit is probably 8 or more years old. Any idea own what parts and cost may be involved to repair it? I'd most likely do the repair work myself.
Thank you for your help!
-Don:)
sidfink43
#2 Posted : Saturday, July 23, 2011 5:57:32 PM(UTC)
sidfink43
Assuming it is draining ok, you want to check out the clutch and brakes. The clutch is a relatively easy and inexpensive repair. Check the brakes using the Sticky by Richappy at the top of this page.
Here is a video on the clutch.
‪Washing Machine Clutch Band and Lining Repair Kit Replacement (part #285790)‬‏ - YouTube
DoSchultz
#3 Posted : Monday, July 25, 2011 6:16:12 AM(UTC)
DoSchultz
Thank you for the response and directions. I do not know what you mean by the "Sticky by Richappy". I don't find that information or reference on the page.
sidfink43
#4 Posted : Monday, July 25, 2011 6:46:00 AM(UTC)
sidfink43
It is at the top of the washer forum page.
Guest (4)
washer drum will not spin (Washer Repair)
by hlsjmc1 3/12/2010 4:32:50 PM(UTC)
by craigjr 8/27/2008 3:58:45 AM(UTC)
