vrajkuma
#1 Posted : Friday, July 22, 2011 6:36:50 AM(UTC)
vrajkuma
Model: 66515819990, Kenmore Ulta Wash
My dishwasher suddenly refuses to turn ON. I do not see any lights in the panel. I checked the circuit breaker and it seems fine. I even switched it OFF/ON. I also notice about 1.5 inches depth of water in the base of the dishwasher.
1. Could this just be a drain clog problem or drain pump issue. I see the drain pipe from dishwasher connected to the garbage disposal higher than water level in dishwasher. So I assume the pump needs to work to pump out the water. How can I test if pump is fine or get it to drain.
2. Could this be a fuse issue. How can I test if dishwasher is getting electrical power. I don't see a power receptacle to test, so the power wiring is going directly into dishwasher I assume. I don't have a meter, but a simple electrical tester. Do I need a meter to debug this
thanks. any help/pointers appreciated.
#2 Posted : Saturday, July 23, 2011 1:34:05 PM(UTC)
Replacement parts for KENMORE 66515819990 | AppliancePartsPros.com
[COLOR="DarkRed"]1. Could this just be a drain clog problem or drain pump issue. I see the drain pipe from dishwasher connected to the garbage disposal higher than water level in dishwasher. So I assume the pump needs to work to pump out the water. How can I test if pump is fine or get it to drain.[/COLOR]
I doubt this is your problem as a drain pump will not kill power to the unit unless it has shorted out which is unlikely.
The unit is probably hard wired to the house wiring with a couple wire nuts.
This will be behind the kick plate.
You will have to remove the wire nuts and check for power just be very careful that they do not short to each other or the machine frame.
A high probability is the thermal fuse which is on the control board in the door.
Part number: AP3115186
Often they just blow on their own. If it is blown be sure to use the new harness that comes with it. Sometimes another part will cause it to go but the only real way to tell is give it a try unless you have a clamp on ammeter.
Flip the breaker to the unit. Then open up the door, remove the fuse and check it with a meter, should be 0 ohms.
[COLOR="DarkRed"]
I don't have a meter, but a simple electrical tester. Do I need a meter to debug this[/COLOR]
I would get a meter as you can measure resistance (ohms) which is a lot safer as the power is off. Also it gives more info than what you have.
You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
File Attachment(s):
15819990.pdf (484kb) downloaded 10 time(s).
vrajkuma
#3 Posted : Saturday, July 23, 2011 7:16:05 PM(UTC)
vrajkuma
Thank You. I will try out the fuse with multimeter and order part if broken.
Dishwasher won't turn on (Dishwasher Repair)
by dkwtmcmanus 11/27/2012 9:52:16 AM(UTC)
Maytag Dishwasher won't turn on (Dishwasher Repair)
by mp847 5/25/2012 3:54:59 PM(UTC)
Maytag dishwasher won't turn on, nonresponsive (Dishwasher Repair)
by tolsun 5/18/2011 6:13:46 PM(UTC)
Whirlpool Dishwasher won't turn on (Dishwasher Repair)
by alexp1322 12/1/2010 5:17:20 PM(UTC)
Help! Dishwasher won't turn on (Dishwasher Repair)
by ctralw 9/20/2010 4:24:27 PM(UTC)
Dishwasher won't turn on. (Dishwasher Repair)
by Dmccray 1/11/2010 11:11:21 AM(UTC)
Kitchen Aid dishwasher won't turn on (Dishwasher Repair)
by kud124 se 6/16/2009 10:14:25 AM(UTC)
by Akupferman 12/4/2008 2:31:56 PM(UTC)
Whirlpool dishwasher won't turn on (Dishwasher Repair)
by beginner 12/27/2007 7:31:28 AM(UTC)
