Lg Window Unit Compressor Runs The Entire Time The Unit Is Turned On. Turning Thermostat All The Way Up Does Not Even Shut It Off. Air Is Plenty Cool. What Could Be The Problem?
THIS FORUM IS DEAD!!!!!!! |
RY COMP connections are not welded together and connections are tight. Manuel says to then check the RY COMP itself. How do I do that?
I am not sure what they mean. You have checked it since the contacts are not welded together the control board is energizing it all the time so the problem is further back in the unit. |
