tdeai
#1 Posted : Thursday, July 21, 2011 3:55:49 PM(UTC)
tdeai
I am having trouble with my dryer. It won't dry the clothes, not getting any heat. I just replaced the heating element assembly and thermostat sensor but I am still not getting dry clothes.
Does anyone have any answers????
Tom
#2 Posted : Friday, July 22, 2011 4:18:45 AM(UTC)
Here are your parts includes a wiring diagram.
Replacement parts for MAYTAG MDE5500AYW DRYER- ELE | AppliancePartsPros.com
Did you replace the parts in an attempt to fix the no heat problem and did not do any troubleshooting but felt they were the most likely cause?
Also I am not sure what thermostat you replaced.
You have 2 thermostats in the heater circuit and also a thermistor (sensor) connected to the control board.
First I would check the power.
The heater requires the full 240 volts while the control, motor etc. only require 120 volts.
Try flipping the breaker off/on slowly a couple times.
Sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
Guest (4)
