schnitz52
#1 Posted : Wednesday, July 20, 2011 8:04:03 AM(UTC)
schnitz52
The [FONT="Calibri","sans-serif"]theRinse Aid dispenser will no longer screw in and stay in. I am not sure if theissue is I need a new fill cap or if the receptacle it screws into has lost itsthreads and a new one will not help. [/FONT]
#2 Posted : Friday, July 22, 2011 4:08:41 AM(UTC)
Replacement parts for GSD1200G01 models | AppliancePartsPros.com
Since there is no G01 shown I would use G02.
Check the threads on the cap (Item 829 in Section 1) if they look OK then you will need a reservoir (Item 811 in Section 1).
Since the parts are cheap I would order both of them.
If the threads on the cap are bust off I would just get a replacement cap.
