kaddman
#1 Posted : Monday, December 8, 2008 8:32:10 AM(UTC)
kaddman
please need information about installing ice maker which is included with the refrig. mfg#P1196710WL The directions mentioned a plate water valve to be connected
thanks
kaddman85@yahoo.com
#2 Posted : Monday, December 8, 2008 4:51:27 PM(UTC)
Can you be more specific on the problem? I'm afraid I did not get it clear.
kaddman
#3 Posted : Tuesday, December 9, 2008 10:59:09 AM(UTC)
kaddman
we want to Install an Ice Maker it calls to install a water valve #AP87907 at the refrig that we understand we already installed a water valve and a water line to the refrig from there it's not clear where to go and at the the frezeer is there any ice cube reciever to install???
thanks Gene for your reply
#4 Posted : Tuesday, December 9, 2008 11:10:18 AM(UTC)
According to the model number you posted the ice maker should be already there. If it's not, then I need the part number for the ice maker you are going to install. Also you'll need the water supply line to the refrigerator. Do you have it?
kaddman (Refrigerator & Freezer Repair)
by kaddman 12/11/2008 10:41:06 AM(UTC)
