lbarca2
#1 Posted : Monday, December 8, 2008 7:11:31 AM(UTC)
lbarca2
when the power is turned on to appliance, the broiler element comes on and stays on. if the relay is stuck, should the oven sensor cycle at some temperature? it must be close to 700 degrees in there. also could the clock be bad and send a false signal to the relay board and cause this situation? i wouldn't mind replacing all three items, clock, relay board, and sensor but their availability comes into question
#2 Posted : Monday, December 8, 2008 4:11:18 PM(UTC)
Most likely the problem is a stuck relay on the relay board. In such case it does not respond to any command from the control board.
- The part number for the relay board is AP379875 and it is good in stock.
