hello n thx, i have a kenmore washer and it just started makin very loud noise or hum when during cycle,and leaked some water on floor. wondering if this is somewhat of an easy fix and what to replace. thx 4 your time
checking to see if email responce is workin
Check the PUMP, Its located in the FRONT CENTER of the washer.
do ya think it sounds like i should replace it or maybe somethin is clogging it. idk so i have to ask. it just started makin the noise, like a whine sound but pretty loud. anyhow thanks for your reply, i will check into the pump
