burners will not come on ---can't reset clock
Originally Posted by: Phillip88 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) burners will not come on ---can't reset clock Phillip, Did you reset the breakers at the breaker box, and make sure you have 240 VAC, at the outlet and range terminal block ? From there, you'll need to remove the rear control panel and start looking for a shorted wire harness and switches. Good Luck, :) :) :)
