2 Pages12>
Charlie57
#1 Posted : Monday, December 8, 2008 2:31:50 AM(UTC)
Charlie57
I have a Whirlpool refrigerator that the ice dispensor quit working. There is no sound like a motor trying to work, the piece that turns to dispense the ice is ok and will turn free, when removed from unit.
The unit makes and and dispenses water fine, everything else works fine.
Any Advice?
Charlie
#2 Posted : Monday, December 8, 2008 3:14:22 PM(UTC)
Hi Charlie,
What is the complete model number of the refrigerator?
Charlie57
#3 Posted : Monday, December 8, 2008 6:08:47 PM(UTC)
Charlie57
Gene,
The Model is ED5FHEXLQ00
Manufacture Date 06-02
I appreciate any help!
Charlie
#4 Posted : Tuesday, December 9, 2008 12:46:30 PM(UTC)
Charlie,
Did the ice gate in the door open when you push the ice lever?
Did you hear a click when you tried to get an ice cubes?
Charlie57
#5 Posted : Tuesday, December 9, 2008 2:14:51 PM(UTC)
Charlie57
Gene,
The door does open and there is no sound at all. Not even a click, it woud be no different unpluging the fridge and testing it.
Charlie
#6 Posted : Wednesday, December 10, 2008 8:07:35 AM(UTC)
Charlie,
Remove the ice bin and the bracket (#1 on the break down diagram).
Remove the wires from the motor and check the motor for continuity.
Check for 120VAC to the motor while the dispenser calls for ice and the door light switch depressed.
Post the results.
Charlie57
#7 Posted : Friday, December 12, 2008 2:21:05 AM(UTC)
Charlie57
Gene,
Thank you for the information. I will do this on Sunday. I'll let you know what happens.
Thanks,
Charlie
Mark Minnick
#8 Posted : Saturday, December 13, 2008 4:43:39 PM(UTC)
Mark Minnick
I am having a very similar problem with my Whirlpool icemaker - makes ice just fine but won't dispense crushed or cubed. When pressing the pad, it makes a noise that sounds like a low hum (has always made this noise) and then nothing follows.
Model # GF6NFFXTY00
Serial # SU1131453
Charlie57
#9 Posted : Saturday, December 13, 2008 5:04:03 PM(UTC)
Charlie57
Mark,
I am going to try to trouble shoot mine Sunday. Are you sure the low hum is not the sound of the cold air you can here when you push the dispensor. Also our flap (that makes the seal) makes a funny noise as it closes.
Charlie
#10 Posted : Sunday, December 14, 2008 4:29:43 PM(UTC)
Mark,
The model number you posted does not come up. Verify and repost it.
2 Pages12>
