I have A Dacor ERD48 RANGE, the oven light turns on and off when it wants, sometimes rapidly or it will stay off for a period of time. Thanx
Rank: Administration
Just what I needed. I think I have it figured out. There is an extension harness between the ribbon connector and the board. Wiggle test the plug and find the relay goes nuts. Cleaning the pins at the point where the harness and ribbon mate appears to have solved the issue. Thanks Dave
Good job, Dave. Happy Holidays!
