#1 Posted : Tuesday, July 19, 2011 1:02:31 AM(UTC)
Does anyone know where I can get a service manual for this 2 yr old washer?
Joe / APP Team
#2 Posted : Tuesday, July 19, 2011 5:35:38 AM(UTC)
Joe / APP Team
Rich,
Looks like a basic "Duet" front load washer.
What seems to be wrong ? may be I could help ?
We can't copy and or send from the system, makes things rough sometimes.
#3 Posted : Tuesday, July 19, 2011 5:41:16 AM(UTC)
The washer flashes a F71 code and the motor will not run. Diagnostics says to check ccu and communication lines. I suspect a bad connection
All the unit will do now is beep when you press the on button, no lights go on.
Joe / APP Team
#4 Posted : Tuesday, July 19, 2011 10:27:02 AM(UTC)
Joe / APP Team
Rich,
You have it coverred, a communication error.
A quick check, disconnect the motor control harness from the CCU, if the code disappears, bad motor control board or loose connection. if the code stays bad, CCU.
:cool: :cool: :cool:
#5 Posted : Tuesday, July 19, 2011 1:08:07 PM(UTC)
Thanks Joe, I heard of that test before, but the washer is really dead now, nothing displayed. Anyway, told customer to get a repair site that has access to factory advice.
Joe / APP Team
#6 Posted : Tuesday, July 19, 2011 2:08:14 PM(UTC)
Joe / APP Team
Rich,
Well, you tried, if it's a "goner" I would presume the CCU gave up. I wish ServiceMatters was a bit more "friendly". I should have downloaded as much as possible before they went to a "proprietary" web site.
Guest (5)
