tedc57
#1 Posted : Monday, July 18, 2011 6:19:33 AM(UTC)
tedc57
My stove stopped working today. Both the oven and top. The lights still come on but nothing heats up.
#2 Posted : Tuesday, July 19, 2011 4:48:35 AM(UTC)
ES300 is not a model number I think it refers to the electronic control board.
A model number would be useful if the following doers not help.
Model Number Locator
It sounds like a power problem as the oven and stove top are usually separate other than power in (240 volts).
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
Frigidaire stovetop light on (Oven Repair (including Ranges and Cooktops))
by RickM1957 1/22/2022 8:40:19 AM(UTC)
FRIGIDAIRE STOVE MODEL LGGF3043KFM (Oven Repair (including Ranges and Cooktops))
by SATJAN15 1/15/2022 10:46:37 AM(UTC)
Frigidaire Stove Burner Gets too hot, replaced infinity switch (Oven Repair (including Ranges and Cooktops))
by questionforyouguys 7/11/2016 1:37:01 PM(UTC)
Frigidaire Stovetop elements, oven, and broiler wont heat (Oven Repair (including Ranges and Cooktops))
by janniiie 1/17/2016 2:35:18 PM(UTC)
Frigidaire Stovetop stuck on HE (Oven Repair (including Ranges and Cooktops))
by Jbell719 12/19/2014 7:16:18 PM(UTC)
Frigidaire Stove F10 Error (Oven Repair (including Ranges and Cooktops))
by ronusmc 1/4/2014 8:08:21 AM(UTC)
Frigidaire stove makes screeching sound (Oven Repair (including Ranges and Cooktops))
by jpurdy 11/26/2013 5:49:02 AM(UTC)
Frigidaire stove top igniter partially working after self cleaning (Oven Repair (including Ranges and Cooktops))
by chenson 4/3/2013 3:48:59 PM(UTC)
frigidaire stove burner gets to hot (Oven Repair (including Ranges and Cooktops))
by kattsman 3/3/2012 4:26:24 PM(UTC)
Element on Frigidaire Stove not turning off (Oven Repair (including Ranges and Cooktops))
by husk 12/15/2011 8:58:45 AM(UTC)
Frigidaire Stove looking Transformer voltage output info (Oven Repair (including Ranges and Cooktops))
by Marc Ernst 1/1/2011 9:45:06 AM(UTC)
In need of help with Frigidaire Stove (Oven Repair (including Ranges and Cooktops))
by adam8588 11/10/2010 3:01:35 PM(UTC)
Frigidaire Stove/Range Large burners not getting Hot (Oven Repair (including Ranges and Cooktops))
by Looney102 3/7/2010 8:19:32 AM(UTC)
Burner ignitor replacement on Frigidaire stove (Oven Repair (including Ranges and Cooktops))
by kurb 3/1/2010 12:33:26 PM(UTC)
Frigidaire Stove - broiler wont shut off (Oven Repair (including Ranges and Cooktops))
by Peg529 2/15/2010 1:25:13 PM(UTC)
