Unfortunately all you can do is make sure it is getting the correct power and run the diags.
On a standard keyboard you can check that the switches are working but it does not look like this is a possibility with this keyboard as it has active components(IC's etc.) on it.
But it is now working and you are getting an error so I would try to track down the cause of this. |
THIS FORUM IS DEAD!!!!!!! |
Thank you again. The diagnosis says bad user interface so I guess it goes back.
Thank you very much for all of your help.
I just wanted to thank denman and Kayakcrazy for the help each of them gave me. The second user interface arrived a couple of hours ago. This one was well packed and protected. It fit perfectly and when I plugged it in and pushed "start" the machine came to life. Now if the washer will last more than two years after this fit ....
Good Job. Glad you finally gort it. Tom
