carlos brandon
#1 Posted : Monday, July 18, 2011 9:48:17 AM(UTC)
carlos brandon
change out the main board and the defrost thermostat .the ref. will defrost when the first defrost cycle began but will not defrost when the time for next to began.
#2 Posted : Tuesday, July 19, 2011 6:30:02 AM(UTC)
Go to the second sticky above for GE refrigerators. Search for the manual defrost test using the motherboard connector. This will isolate your problem.
