ed wilson
#1 Posted : Sunday, December 7, 2008 4:12:01 PM(UTC)
ed wilson
The dryer continues to run except when in the timed mode. Is it a moisture sensor or heat sensor?
kayakcrzy
#2 Posted : Monday, December 8, 2008 4:20:14 AM(UTC)
kayakcrzy
I did not see a sensor on your model. But I would first make sure the vent is clear to the outside, and also take the front off, and then the blower housing, which is held in by Four 5/16s screws. Two on each side. Then try it. If it does not work I would replace the thermostat located on the blower housing. Tom
ed wilson
#3 Posted : Tuesday, December 9, 2008 7:55:09 AM(UTC)
ed wilson
Thank you for the advice. Makes sense. I will try it.
kayakcrzy
#4 Posted : Wednesday, December 10, 2008 3:30:04 AM(UTC)
kayakcrzy
Good Luck. Tom
