HELP - We have standing water at the base of the spray arm and loads of debris in the strainer. I am having no luck removing the spray arm or strainer. Our dishes, particularly the top rack, are drying with filth. Please help. TIA
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
THIS FORUM IS DEAD!!!!!!! |
Sorry, could you try Model # GSD4020202BB Serial # VT769229B
Thanks Again
Tried Model GSD4020Z and see you probably have a jammed drain solenoid. Part AP2039683
Remove your kick panel under the door, the drain solenoid is attached to the motor. With a little skill, you can replace it without pulling out the dishwasher.
