Bonkers
#1 Posted : Friday, July 15, 2011 6:33:45 PM(UTC)
Bonkers
We purchased a replacement drive wheel belt but it won't stay on. The drive wheel is a bit wobbly. Is it supposed to be firm? We may need to replace something in addition to the belt but I don't know what it might be.
sidfink43
#2 Posted : Saturday, July 16, 2011 4:48:45 PM(UTC)
sidfink43
You need to put a new nut on it, as the old one will be damaged and unusalbe after you take it off.
Caution: The nylon locking material used inside
the drive nut will be damaged upon removal. Use
replacement drive nut (Part # WH02X10211) when
reinstalling the tub drive pulley. Use a torque
wrench to tighten the 24-mm hex nut to 44 ft. lbs of
torque.
(from the service manual)
