Doug Lawheed
#1 Posted : Friday, October 26, 2007 7:37:38 AM(UTC)
Doug Lawheed
after numerous times of removing ice in bottom of freezer, we tried defrosting all coils under back panel, also the drain hole. two days later we have the same sitiuation. the temp is set @ #2.
#2 Posted : Friday, October 26, 2007 9:17:18 AM(UTC)
Hi Doug
How did you defrost it?
I would recommend remove all shelves and the back panel. Using a hair dryer, defrost all ice under the evaporator coils and the drain hole, then using a cup with very hot water make sure water goes through the drain.
If it does not, remove the cover on the back of the fridge, locate the end of the drain hose and make sure it is not clogged.
Good luck.
Doug Lawheed
#3 Posted : Saturday, October 27, 2007 8:17:13 AM(UTC)
Doug Lawheed
Dear Gene,
Thank you for the information. We defrosted with dryer again, and this time took the back off and cleared the drain hose. Checked the defrost heater and it was 1.8 ohms, and defrost thermostat was normally open, but schematic showed it normally closed, which I believe to be incorrect.
I think our problem is solved, but I should know in a day or two.
Thank you again for your help.
Doug
Water leaking out of freezer door, ice in bottom of freezer (Refrigerator & Freezer Repair)
by errolarena 11/18/2013 7:38:46 AM(UTC)
Ice in bottom of freezer (Refrigerator & Freezer Repair)
by CathleenM 10/19/2012 4:41:37 PM(UTC)
by randerso2 8/8/2012 9:19:20 AM(UTC)
by pgodaddy 5/20/2009 7:36:40 AM(UTC)
water/ ice in bottom of freezer (Refrigerator & Freezer Repair)
by blford 1/22/2009 3:04:40 PM(UTC)
Water pooling as ice in bottom of freezer (Refrigerator & Freezer Repair)
by rankell 9/21/2008 9:01:21 AM(UTC)
by mudslidemellie 8/7/2008 4:44:00 PM(UTC)
Freezer Coils not defrosting and Ice in bottom of freezer (Refrigerator & Freezer Repair)
by bobbertj 4/1/2008 5:38:39 PM(UTC)
by king1 1/10/2008 1:40:32 PM(UTC)
