My whirlpool microwave gives "door" error message when you enter cook time and push start. I have replaced both the left and right door switch and still get the error. Is there some other door sensor switch that needs to be replaced or what? The model is GMC275PDB07. Thanks.
Originally Posted by: swanson  My whirlpool microwave gives "door" error message when you enter cook time and push start. I have replaced both the left and right door switch and still get the error. Is there some other door sensor switch that needs to be replaced or what? The model is GMC275PDB07. Thanks. I have the same problem recently. I have not seen any reply to your problem. How have you fix it?
