bo_okie1
#1 Posted : Friday, July 15, 2011 6:23:34 AM(UTC)
bo_okie1
My front load washer is showing a f3 error code can someone tell me what the problem is?
Jeff / APP Team
#2 Posted : Friday, July 15, 2011 7:09:20 AM(UTC)
Jeff / APP Team
Hello bo_okie1. The F3 error code is for heater shorted to ground. You will need to test the heater between the contact and the housing. It is normally 2MW. If it is bad, you will need to replace the heater. Hope this helps.
Part number: AP3865677
bo_okie1
#3 Posted : Friday, July 15, 2011 7:21:10 AM(UTC)
bo_okie1
Thanks Jeff,we live where the water is really hard can this contribute to the problem and haow do i access the element?
Jeff / APP Team
#4 Posted : Friday, July 15, 2011 7:34:11 AM(UTC)
Jeff / APP Team
Hello bo_okie1. To access and test the heater, you will need to remove the bottom toe panel of the washer. There are some screws across the bottom you will remove and the toe panel pulls out and down. Once removed, you will see the heater terminals on the front of the washer tub at the bottom. You can test the heater there. Hard water can cause the heater to fail more quickly. Hope this helps.
