Runs whenyou open the door. I have read about the door switch. Do I need both? What part numbers and is there instructions on install. Thanks Mike Found you from Google
Hello Mikes. Based on the information you provided, it sounds like the door switch is bad. You will need to test them and see which one is bad. DOOR SENSING, PRIMARY INTERLOCK AND MONITOR SWITCH REMOVAL This procedure should be followed when replacing switches, otherwise they could be damaged. 1. Disconnect oven from power supply and remove outer case. 2. Discharge high voltage capacitor. 3. Disconnect wire leads from the switch(es). 4. Remove two screws holding the interlock bracket to component compartment flange. 5. Lift latch switch bracket assembly to release catch on bracket (top of bracket) to flange. I . When the door is opened, the monitor switch contact closes (to the ON condition). At this time the primary interlock switch and power relay are in the OFF condition (contacts open). 2. As the door goes to a closed position, the monitor switch contacts are first opened and then the door sensing switch and the primary interlock switch contacts close. (On opening the door, each of these switches operate inversely.)
3. If the door is opened, and the primary interlock switch and power relay contacts fail to open, the monitor fuse blows simultaneously with closing of the monitor switch contacts. CAUTION: Before replacing a blown monitorfuse, test the primary interlock switch, door sensing switch, monitor switch andpower relay contactsfor proper operation.
Primary Interlock Switch Test Isolate the switch and connect the ohmmeter to the common (COM.) and normally open (NO) terminal of the switch. The meter should indicate an open circuit with the door open and a closed circuit with the door closed. If improper operation is indicated, replace the primary interlock switch.
HOW TO TEST MONITOR: 1. Disconnect power, open control panel, and discharge capacitor. 2. Disconnect monitor switch leads, and test at terminals: Door closed---some Ohms (infinity) Door open--0 Ohms 3. Reconnect switch wiring. 4. Test Circuit Operation: A) Connect temporary jumper across relay contacts and primary switch to simulate shorted switch contacts. Locate convienent connections in circuit to be certain COM and N.O. terminals are used. B) Connect OHM meter (LOW scale) across the two line terminals of appliance power cord. Continuity must show: Door Closed--some Ohms Door open-- 0 Ohms C) Remove 20 Amp. Fuse --Circuit must open ( Ohms). If not, check wiring of monitor and interlock circuits. 5. WARNING: After test, remove temporary jumpers and reconnect monitor switch leads.
How To Adjust Interlocks: The switch housing is adjustable for door fit and switch operation. 1. Disconnect power, open control panel, and discharge capacitor. 2. Loosen both switch housing mounting screws at enlarged holes in vertical flange. 3. Adjust switch housing for proper switch operation, and door fit. Retighten screws. Part number: AP2024337
