my control asm. (control board) would only light specific lights and each button would beep when pressed but would not light up or function. I replaced the control assembly, the bottom row of lights all blink - nothing else will happen. Does the control asm. need reset? If so, how. I can't find info. anywhere to do this. Thanks!
I beleive there is a reset procedure for this unit, and the instructions should have come with the part. Unfortunately GE does not make its tech info available, so I can only suggest you contact them and see if they can provide you with the info.
