Yea it does--if by "ice gate" you mean the mouth where the ice comes out.
Perform the motor troubleshooting as described in the attached file. Post the results. Gene.
Is there more to the manual? I don't know how to remove the entire motor compartment as shown in the pic to get to the wire harness
One of the two attached instructions should work with your refrigerator. Gene.
Originally Posted by: Gene ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) What is the complete model number of the refrigerator?
Gene. I'm also getting the same error code, two quick blinks, pause, and repeat for a Kenmore Coldspot Model # 106.53669300. The water fills the tray, it freezes, but it never harvests into the bin.
Did you press the emitter flapper door to unblock the optics beam before checking the LED?
Originally Posted by: Gene ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Thank you so much. I'll give it a whirl.
