3 Pages<123>
erikk71
#11 Posted : Wednesday, July 13, 2011 2:04:01 AM(UTC)
erikk71
nothing happen
Does the wire on common an overload go back to start capacitorwhere there is red wire
should be two red wire on then blue an white on other side of start capacitor
On the top of relay the spot to plug in a wire where do that wire go
On the bottom of relay do i plug wire in all i i see the copper coil
#12 Posted : Wednesday, July 13, 2011 3:10:43 AM(UTC)
You probably have a bad component. I would order a new start device, AP4503032 for this, comes with wiring info.
erikk71
#13 Posted : Saturday, July 16, 2011 8:55:37 PM(UTC)
erikk71
Here is my relay an start capacitor.
I know relay is not rats a wire into thats all
I have red wire red wires on on one side of the start capacitor
I assume one of the red wire is attached to overload that goes to common
The other red wire is made onto the relay the bottom of relay
Next we have the other side of start capacitor that has two prong
the blue coming off the side of the relay next we have a white wire
i see a place to plug wire beside blue wire
next i see a a place to wire on top of relay
erikk71 attached the following image(s):
#14 Posted : Sunday, July 17, 2011 1:53:24 AM(UTC)
The Sears parts site is down right now, check it later for a schematic.
erikk71
#15 Posted : Sunday, July 17, 2011 7:42:30 AM(UTC)
erikk71
I got a SUPCO Powerstart Relay Capacitator Overload RCO810
it says for 1/12 to 1/3 compressors
I installed the freezer cools but not freezing gets to about 53 degrees
#16 Posted : Sunday, July 17, 2011 12:05:30 PM(UTC)
Wait for a few more hours, will take time to reach temperature.
erikk71
#17 Posted : Sunday, July 17, 2011 1:16:35 PM(UTC)
erikk71
I waited 24 hours could the start capacitor in that supco not be strong enough
erikk71
#18 Posted : Sunday, July 17, 2011 1:18:08 PM(UTC)
erikk71
Will the part AP4503032 allow me too hook the start capacitor to it
#19 Posted : Monday, July 18, 2011 1:05:46 AM(UTC)
If the freezer temperature cannot go any lower, you have refrigeration problems for a pro to look at, fridg probably not worth extensive repairs.
erikk71
#20 Posted : Monday, July 18, 2011 5:43:02 AM(UTC)
erikk71
The part from i mentioned earlier
will it allow for me to hook a start capacitor to it,
The freezer was working fine i just need a relay an overload that will allow to hook up the start capacitor to it
Guest (4)
3 Pages<123>
