rhondap
#1 Posted : Tuesday, July 12, 2011 1:07:11 PM(UTC)
rhondap
My Freezer Is Not Getting Cold And Compressor Gets Hot, Is No Oil Leaks Around Compressor, Can Hear It Turn On, But Nothing Is Happening, Worked Great Put In Storage For 1 Year, When We Pulled It Out Now This Happens, Any Ideas Where To Start.
#2 Posted : Wednesday, July 13, 2011 2:22:07 AM(UTC)
Replacement parts for FRIGIDAIRE FFC0522DW4 Frigidaire/freezer | AppliancePartsPros.com
It does not sound good.
Double check that the compressor is running you should be able to feel it vibrating.
It it is running and you are not getting any cooling then you have a sealed system problem and it will be an expensive repair as you need a pro.
Usually it makes more sense to put those dollars towards a new unit.
Note: If the unit when moved was handled at an angle or on it's side, did you let it sit unplugged for 24 hours?
If this is the case unplug it and let it sit for the 24 hours then plug it back in and give it a try.
