3 Pages123>
erikk71
#1 Posted : Tuesday, July 12, 2011 3:14:45 AM(UTC)
erikk71
I recently had mouse the eat the white wire that goes to the compressor.
There is two red an white that u hook up to give electricity to power the compressor.
A relative took the off the compresor where common start run prongs
he made a mess.
This unit has four prong running capacitor.
i need diagram on how rewire it back up a few of the wire on the capacitor
an overload relay were showing signs of age.
So the wiring diagram would be helpful
I have hooked up other refrigerator compressors fine fine just not one that has this 4 prong running capacitor
thank you
erik
running capacitor
showing their age.
#2 Posted : Tuesday, July 12, 2011 4:59:14 AM(UTC)
This is a very old refrigerator. The wires from the refrigerator are red and white. The two red wires get shorted together and go to the spade terminal on the coiled start relay, the white wire goes to the round overload, there is no run capacitor. The start relay plugs into the bottom two compressor terminals, the overload plugs into the top terminal.
erikk71
#3 Posted : Tuesday, July 12, 2011 9:49:40 AM(UTC)
erikk71
Is there any wiring diagrams for the compressor.
What is the the black round capacitor.
erikk71@aol.com
I need something i can see. I am trying to get a picture in my mind on how the the thing goes together
#4 Posted : Tuesday, July 12, 2011 10:29:19 AM(UTC)
I saw your compressor parts at the Sears parts site, but it had no schematic.
I did see a start capacitor though. If you have a meter, I can direct you to wire it up.
erikk71
#5 Posted : Tuesday, July 12, 2011 3:38:39 PM(UTC)
erikk71
On the capacitor there should be two red wires then white an blue
On this setup there was wire going to common i think i maybe wrong/
I tried a different relay over load the compress on 10 secs came then shut off
I also took pics of the relay an capacitor.
I will need to edit thesize of the photos they like 3mb each
erikk71
#6 Posted : Tuesday, July 12, 2011 3:44:42 PM(UTC)
erikk71
I remember seeing the white wire which was chewed into pluged on the relay
I have question i assome the coiled wire faces down
#7 Posted : Wednesday, July 13, 2011 12:34:37 AM(UTC)
`The old compressor terminals where common pin on top , start pin, bottom left and run pin bottom right. The overload wire (the round item) plugs in the top pin, the relay plugs in the bottom two pins. One fridg wire plugs into the overload, the other plugs into the coiled relay. The condensing fan wires are in parallel to the refrigerator wires.
erikk71
#8 Posted : Wednesday, July 13, 2011 1:08:07 AM(UTC)
erikk71
On the relay the bottom of it I see the coiled copper wire.
Does a red wire plug on there.
On the top of relay there is blue from start capacitor going to the relay.
See there was a white wire the one that was broke on top
Would a picture of the relay help
erikk71@aol.com u can email me if u think that be more helpful
erikk71
#9 Posted : Wednesday, July 13, 2011 1:21:38 AM(UTC)
erikk71
I have a white an blue wire on the start capacitor the blue goes to the relay/
the white wire i have going the overload switch going to common.
Next we have the red wires on the start capacitor.
I see only one place on the relay to plugin a wire on the top side.
#10 Posted : Wednesday, July 13, 2011 1:32:14 AM(UTC)
Seems ok to me, just plug everything in and it should run.
Guest (6)
3 Pages123>
