Help still can't get heat. I have checked hi limit thermostat, thermo fuse, the heater element, thermister temp control, the other thermister temp control, all showing resistance. there was a clog of lint in front of the blower but i cleaned everything out everything checks out but heat is not coming on??????? What to do?
Hi, we had about the same prob. We were not getting 220 to our dryer, so check from the breaker to the plug and make sure your wires are tight. I had some that had came loose some how. Hope this could be of help.
