jcoreno
#1 Posted : Friday, October 26, 2007 1:00:10 PM(UTC)
jcoreno
How do you remove the Ice dispenser from the freezer door to replace the gasket?
fixxit
#2 Posted : Friday, October 26, 2007 1:19:28 PM(UTC)
fixxit
are trying to replace the dispenser door flap seal. if so you can simply open the freezer door (this will disable the auger) open the door flap and pull the seal off of the flap. if your talking about another seal you will have to clairify.
#3 Posted : Friday, October 26, 2007 1:21:11 PM(UTC)
Hi jcoreno
- Here is the ice and water dispenser break down diagram for the Whirlpool refrigerator Model ED22GWXWN10
The front dispenser cover can be removed by inserting a screwdriver blade into the two slots on the bottom side of the cover. By gently turning the blade, the cover will snap free at the bottom and can be slid upward to be removed.
Good luck.
