jennifere
#1 Posted : Thursday, July 7, 2011 5:29:47 AM(UTC)
jennifere
Our dishwasher runs normally but then while sitting water will collect in the bottom - an inch or so of water in a few hours. If we turn off the water intake to the dishwasher it almost stops but we did that while we were gone for a week and there was still some water collected in the bottom when we returned. It drains just fine when we run the drain cycle.
#2 Posted : Saturday, July 9, 2011 5:49:46 AM(UTC)
Replacement parts for WHIRLPOOL GU2500XTPQ6 UNDERCOUNTER DISHWASHER | AppliancePartsPros.com
Sounds like the water inlet valve is not sealing correctly.
This would be my first guess if the water in the unit is clean.
Start a cycle then open the door during the fill the water should stop immediately.
Make sure that the water supply valve is fully open. The inlet valve actually uses the water pressure to help seal the valve.
What is puzzling is that it still leaked in water when you shut off the water supply.
Perhaps this was just the water in the supply line between the shut off and the unit's inlet valve and it stopped when the pressure dropped to zero.
Another possibility is that it is leaking back through the drain line.
Again a puzzle because when no one was home there would not be any water running down the sink drain which could have drained back.
Check that the unit is installed as shown in the following install sheet although it is for a GE the same install recommendations would apply.
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=31-30515.pdf
seldomvisitor
#3 Posted : Tuesday, July 24, 2012 3:49:17 AM(UTC)
seldomvisitor
I realize this reply is somewhat tardy (...) however I've got the identical problem on our Whirlpool dishwasher. The continued leakage of water into the dishwasher even after the house water supply to the washer is turned off is probably caused by TWO things - the inlet valve on the dishwasher needs replacing since it is leaking and the house/undersink cutoff valve to the dishwasher is typical of such valves and actually doesn't work very well (!).
In my house ALL the valves (undersink, under toilet, etc) that I've had to turn off to do whatever have leaked after turning them off - every one of them. Though the leaks are not dramatic, over time they can cause problems if you are relying on them actually being OFF - a drip here, a drip there, before you know it it's a LOT of water (especially if it is a somewhat fast drip). As an amateur with such plumbing I am aghast that this is so, surprised that this is so, and wondering if there's actually a solution to the problem - like using higher quality cutoff valves everywhere in the house?
But, in any case, the OP's dishwasher problem sounds identical to mine and others that have posted here - water leaking into dishwasher - bad inlet valve.
