Eballer55
#1 Posted : Friday, July 8, 2011 12:31:23 PM(UTC)
Eballer55
Defrost heater is broken. Maytag discontinued the part (63001049) and I cannot find it anywhere (including e_bay). Is there a different defrost heater that would be compatible (similar size, resistance, current draw and operating voltage)? If I have to, I can wire a new defrost heater to work with the existing wiring in the refrigerator, but I just want to make sure I have enough heating, but not too much current that the defrost heater element gets destroyed too quickly. I am shocked there is no updated part number provided by the manufacturer. The manufacturer is Maytag by the way and I have talked to them on the phone about this with no resolution.
#2 Posted : Saturday, July 9, 2011 1:07:10 AM(UTC)
Measure the length and diameter of the old element, including the end pieces and tell us if it is iron, or glass.
aretouli
#3 Posted : Tuesday, May 29, 2012 9:36:31 AM(UTC)
aretouli
hi there , i m going through the same problem looking for part 63001049. Where you able to find it or did you end up with a new fridge?
defrost heater discontinued (Refrigerator & Freezer Repair)
by dustins 3/14/2014 11:03:47 AM(UTC)
