geclkt
#1 Posted : Friday, July 8, 2011 3:02:01 AM(UTC)
geclkt
The ice and water dispenser do not work but ice is still made. I will first replace the switch (AP3191616), and if that does not work replace the motherboard (AP4436216). My question is how are they accessed? Do you just have to pry off the Trim Recess panel? If so, how? Do you pry off the Interface display? If so, how? I don't want to break off tabs just to change the switch. Any help would be appreciated!
skszooman
#2 Posted : Friday, July 8, 2011 12:05:30 PM(UTC)
skszooman
I have a electrolux/frigidaire model with similar interface. On mine, yes would be the answer, you remove the trim facia which exposes the screws holding the touch panel etc. I was able to start at the bottom sides of the trim, with my finger tips to the inside and lifting up and outward at the same time. Once the bottom and side were released the top and upper sides followed. Good luck!
