mjmorizio@earthlink.net
#1 Posted : Wednesday, December 3, 2008 5:40:07 PM(UTC)
What might be causing the squealing noise on our Maytag Gas Dryer?
Would it happen to be that the *Roller Bracket* and/or *Cylinder Roller* are shot?
FYI, the noise has gotten increasingly worse over the course of the last month or so. It used to go away after the machine warmed up...now it is a constant noise.
libertyappl
#2 Posted : Wednesday, December 3, 2008 6:16:27 PM(UTC)
libertyappl
Most commonly on these dryers it'sd the rollers or possibly the seals.
Here's the parts breakdown. Model SDG305DAWW
Nat
magician59
#3 Posted : Thursday, December 4, 2008 7:36:42 AM(UTC)
magician59
Low pitch "rumbling noise generally indicates support rollers. High pitch usually points to belt or idler pulley. Metallic "scratching" sound indicates a bad felt seal and/or worn glide bearings.
squealing noise when dryer full and running (Dryer Repair)
by MissFitFL 9/11/2016 11:17:49 AM(UTC)
squealing noise from frigidaire front loader (Washer Repair)
by jimmygabe 11/17/2014 2:20:04 PM(UTC)
Maytag Performa loud squealing noise (Washer Repair)
by jeneerik 4/27/2013 12:49:18 PM(UTC)
Squealing Noise (Dryer Repair)
by moody9207 2/1/2013 8:56:35 AM(UTC)
My GE Dryer is making a squealing noise (Dryer Repair)
by John nut 2/1/2013 8:31:37 AM(UTC)
Agitator not working, squealing noise (Washer Repair)
by lderubeis 3/17/2012 11:34:59 PM(UTC)
Squealing noise after changing Motor Coupler (Washer Repair)
by DanPizano 4/10/2011 11:06:41 AM(UTC)
Washer Making Squealing Noises (Washer Repair)
by CGLANK 1/3/2011 2:49:01 PM(UTC)
dryer makes continuous loud squealing noise (Dryer Repair)
by gfroman 8/11/2010 7:53:34 AM(UTC)
Washer squealing noise (Washer Repair)
by Dave M. 6/6/2010 1:53:11 PM(UTC)
Maytag Dryer makes an awful squealing noise (Dryer Repair)
by cfoley 5/18/2009 12:54:40 PM(UTC)
High pitched squealing noise (Dryer Repair)
by b428337 10/3/2008 8:09:42 AM(UTC)
Squealing noise from Signature 2000 electric dryer (Dryer Repair)
by saumila 2/13/2008 4:14:16 PM(UTC)
