Angelsptouch
#1 Posted : Wednesday, July 6, 2011 12:10:09 PM(UTC)
Angelsptouch
I recently replaced my dryer belt. The tumbler is working fine now. But when I got everything back together, it doesn't heat now, and the timer is not working. It starts and runs, doesn't stop until I open the dryer door. Is it possible to have loosened something when I put the dryer back together? I had this issue posted before and got no response, hoping to re post will get a result. :confused:
#2 Posted : Thursday, July 7, 2011 2:38:48 AM(UTC)
Replacement parts for MAYTAG DE303 DRYER- ELE | AppliancePartsPros.com
I could not find a wiring diagram for this unit.
Check to see if they put one in the control console or it may be glued to the back cover.
First I would check the power to the unit.
The motor uses 120 volts but the heater requires the full 240.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
If the power is OK, unplug the unit and check the heating element.
Should be around 10 ohms.
If OK then check the various thermostats, all should be 0 ohms.
Also the motor will have 2 centrifugal switches one of them provides power to the heating coil perhaps you knocked the wire off when replacinf the belt.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
Angelsptouch
#3 Posted : Friday, July 8, 2011 7:48:05 AM(UTC)
Angelsptouch
Thank you for the information. I appreciate your response, I will try all of those things, until I find one that works. Hopefully 1 will work. :)
Guest (4)
