My GE Refrigerator and Freezer stopped working recently. Both do not cool. The lights turn on, in the freezer the fan works, in the refrigerator there is a very small air flow coming. I think that the compressor does not work. Freezer and refrigerator temps. are both room temperature. When I want to set the temperatures and I raise the temperatures up, the refrigerator turns off and when I lower them, it turns on. So I deduced that the temperature thermostat is working. http://www.geservicenet.com/cc/...erator_AC_Diagnostics.pdI used the following link to test the voltages of the compressor and for checking the main control board, but on my board there is no black wire for the J8 connector. How can I check the compressor? I beg you guys, is there anyone out there that can please help me? I want to do the diagnostic ASAP and order the parts that are needed to be replaced. Thank you in advance, Tamaziuk
Model # will not work on any site.
