mmorgan100
#1 Posted : Friday, October 26, 2007 11:04:11 AM(UTC)
mmorgan100
We received this oven used from a relative. When I turn on the oven I can smell gas, and it takes quite a while for it to reach temperature. I was told by a friend that I probably needed a thermocoupler, but when I went to live chat here on the site I was told it couldn't be found for this particular model. Any help would be greatly appreciated.
Thanks!
Michele
fixxit
#2 Posted : Friday, October 26, 2007 11:15:09 AM(UTC)
fixxit
many newer (less than 5 years) gas ovens will read resistance from the glow bar (ignitor) as a type of thermocouple. visualy check the glow bar for discolorations, specificly an ashy spot. if this is the case it is likely your problem. also check you modle # (likely on either the left or right side front when you open the lower drawer
#3 Posted : Friday, October 26, 2007 11:25:30 AM(UTC)
Hi mmorgan100
Most likely the problem with your oven is a bad bake igniter. Replacing it should solve the problem.
The bake igniter
UserPostedImage
- The part number for the new igniter AP2020569
Good luck.
mmorgan100
#4 Posted : Monday, October 29, 2007 10:20:33 AM(UTC)
mmorgan100
Thanks for your help. Picked up the part today. Just waiting for hubby to get home and put it in. : )
#5 Posted : Monday, October 29, 2007 10:34:08 AM(UTC)
Keep me updated, please.
mmorgan100
#6 Posted : Tuesday, October 30, 2007 4:26:22 AM(UTC)
mmorgan100
WOOHOO! All better. It was the ignitor. Thank you so much! We couldn't have done it without you!
