rfosterk
#1 Posted : Tuesday, July 5, 2011 12:46:58 PM(UTC)
rfosterk
Water line to water dispenser leaking under refrig. if you try to get water there is a pause when air come out before water. Water pours out bottom of refrigerator at back. Is this something that we can fix or is it too complicated? I think it is in the line between the pump and the water reservior behind the crisper drawer.
laverett
#2 Posted : Thursday, July 7, 2011 7:42:18 AM(UTC)
laverett
i have a TPX24BPZCWW Ge profile refrig that is leaking water from the water line in the back left bottom behind the removalable panel. The plastic nut and line tubing was cracked. ordered tubing and nut 1/4 inch but too small, mime is bigger nut and tubing. need help. diagram only shows this nut.
Guest (4)
