Ray J
#1 Posted : Tuesday, July 5, 2011 9:15:57 AM(UTC)
Ray J
Dishwasher does not pump out. Drain & Drain hose have been verified as clear.
When cycle gets to where it should pump ou, we hear a hum & ticking from control panel. Cannot tell if pump is attempting to activate.
How can I determine if it is the control panel or if it is the pump that is not working?
Ardvaark
#2 Posted : Tuesday, July 5, 2011 9:34:22 AM(UTC)
Ardvaark
Disconnect the pump and see if it still hums and clicks at the control. If it does, replace control, if it does not check to see if the pump is locked up or shorted internally..
Ardvaark
Ray J
#3 Posted : Tuesday, July 5, 2011 11:38:49 AM(UTC)
Ray J
Ardvaark
What are the Appliance Pro part numbers for the control & for the pump?
Ardvaark
#4 Posted : Tuesday, July 5, 2011 12:09:57 PM(UTC)
Ardvaark
AP4484688 pump
AP4484676 control
Ardvaark
GE dishwasher GDT695SSJ0SS middle arm not spinning (Dishwasher Repair)
by merrittjr 3/23/2024 10:51:00 AM(UTC)
GE Dishwasher GDF620HMJ2ES (Dishwasher Repair)
by lou@officenerd.com 1/14/2024 3:32:20 PM(UTC)
GSD5120D00BB GE dishwasher leaking at the bottom corners (Dishwasher Repair)
by ron Minervino 12/7/2023 9:15:11 AM(UTC)
GE Dishwasher Model GDT655SSJ2SS (Dishwasher Repair)
by Dan Jones 11/16/2023 11:33:43 AM(UTC)
GDF610PMJ5ES (GE Dishwasher) - No Power to LED Display (Dishwasher Repair)
by txwildcard 6/7/2023 2:40:51 PM(UTC)
GE dishwasher GDT580SSF5SS water doesn't get hot and dishes are not drying (Dishwasher Repair)
by jmbuffy 5/15/2023 4:45:57 PM(UTC)
GE Dishwasher Loads water but never agitates to clean dishes (Dishwasher Repair)
by Guest 4/19/2023 6:38:21 AM(UTC)
GE Dishwasher, Model: GDF530PGM0WW (Dishwasher Repair)
by Guest 4/12/2023 12:06:40 PM(UTC)
GE Dishwasher GSD900D-02 Door Gasket Gap (Dishwasher Repair)
by DJW000 2/5/2023 10:05:34 AM(UTC)
GE Dishwasher dead UI board (Dishwasher Repair)
by Guest 1/26/2023 9:44:03 PM(UTC)
GE dishwasher - general query about a ball at the back in the tube (Dishwasher Repair)
by delboy1881 7/27/2022 7:49:15 AM(UTC)
GE Dishwasher beeps every 10 seconds (Dishwasher Repair)
by bethH 7/12/2022 3:03:53 AM(UTC)
Ge dishwasher seal replacement (Dishwasher Repair)
by Guest 4/21/2022 5:34:16 AM(UTC)
GE Dishwasher - No Power - Replaced Control Board, Wiring Harnes, and UI Board (Dishwasher Repair)
by aervin 4/19/2022 7:32:28 AM(UTC)
GE dishwasher not filling and other problems (Dishwasher Repair)
by Guest 4/14/2022 3:40:35 PM(UTC)
