My front loader is leaking from the tub and dripping out all over the floor..whats its matter?
Is it leaking near the front where the boot is or the center of the tub where they front & rear meet?
Can you please post your model number?
Nat
I think its leaking from around the tub inside not sure of the model number its about 3 years old tho
ok this is what it says eco care system heavy duty 2 way tumble stainless steel and it has these numbers 131674100 9704 where the bar codes are inside the door is washed offf mostly so I cant read anything there
