1azarah
#1 Posted : Wednesday, December 3, 2008 8:33:47 AM(UTC)
1azarah
Our dishwasher will start cycle, fill and then stops. It will try by itself to start again but then shuts off again. we looked to make sure there is no obstructions in the way of the arms, and below where the drain is. It does turn off and drain fine. please help...:confused:
#2 Posted : Thursday, December 4, 2008 3:34:38 PM(UTC)
What is the complete model number of the dishwasher?
1azarah
#3 Posted : Friday, December 5, 2008 11:01:43 AM(UTC)
1azarah
Mdb7600aww
1azarah
#4 Posted : Monday, December 8, 2008 5:33:53 PM(UTC)
1azarah
mdb760AWW.
Still doing it!!!
what should we do?
#5 Posted : Tuesday, December 9, 2008 12:54:57 AM(UTC)
Could not find info on MDB760AWW, please check.
Info below is for MDB7600AWW
You may want to check this out first
https://repair.maytag.co...sher.jsp?siteCd=MT_EN_US
Here is your parts breakdown
Model MDB7600AWW
Here is a Manual and a tech sheet
http://www.servicematters.com/m...ibrary/docs/16021814.pdf
http://www.servicematters.com/m...ibrary/docs/16023212.pdf
Run the diagnostics given in the tech sheet.
I just answered one like this, unit was seeing a high motor current fault.
They replaced the motor and that did not solve the problem.
I recommended they check the wires in the door for rinse aid leakage and then try replacing the motor's start capacitor. Have not heard back but this was just the other day.
If the fault is high motor current and if there is no rinse aid leakage and the wires are good, you may want to start with replacing the capacitor as it is less dollars than a motor.
Whirlpool Cabrio keeps displaying error message & won't continue cycle (Washer Repair)
by leighvalencia 3/29/2009 11:01:45 AM(UTC)
